This car grinds into first gear when RPMS are above idle, it grinds into third gear. I am assuming the syncos are going away???? Would this be a valid assumption? If so how much does it typically cost to repair these. I can pull the tranny myself, but I don't know how to work on the inside.
OR could it be a cluth and/or master / slave cylinder problem??? It works into 2nd,4th, and 5th without and grinding.
Thanks
Thanks
Mar 30, 2009 at 9:44 AM
