1999 Mitsubishi Eclipse Sputters On Acceleration
1999 MITSUBISHI ECLIPSE
KBEUCKE
  • 78 POSTS
Engine problem
1999 Mitsubishi Eclipse Front Wheel Drive Manual 149000 miles
When I accelerate from a stop the car most of the times accelerates fine. However if I am doing 35-40 mph and jump on it, it sputters while accelerating. I have installed a fuel filter, the spark plugs are pretty new, and I just installed a high performance coil. Still sputters. Can you give me a few more things I might check?
Jan 19, 2008 at 12:58 PM
BMRFIXIT
  • 19,053 POSTS
[quote:dfcfc421ea="kbeucke"]Engine problem
When I accelerate from a stop the car most of the times accelerates fine. However if I am doing 35-40 mph and jump on it, it sputters while accelerating. I have installed a fuel filter, the spark plugs are pretty new, and I just installed a high performance coil. Still sputters. Can you give me a few more things I might check?[/quote:dfcfc421ea]
check ignition wires
check tranny
if you have an egr check its operation
Jan 19, 2008 at 1:06 PM
KBEUCKE
  • 78 POSTS
So where do I find the EGR? And what do you mean check tranny?
[quote:163b546fb5="BMRFIXIT"][quote:163b546fb5="kbeucke"]Engine problem
When I accelerate from a stop the car most of the times accelerates fine. However if I am doing 35-40 mph and jump on it, it sputters while accelerating. I have installed a fuel filter, the spark plugs are pretty new, and I just installed a high performance coil. Still sputters. Can you give me a few more things I might check?[/quote:163b546fb5]
check tranny
if you have an egr check its operation[/quote:163b546fb5]
Jan 19, 2008 at 1:21 PM
BMRFIXIT
  • 19,053 POSTS
EGR LOCATION
left of rear engine 2.0 none turbo
2.4 and turbo by the fire wall
make sure that your problem is from the engine and not the tranny that giving you the hesitation
check fuel pressure and fuel flow
and MAF sensor
Jan 19, 2008 at 1:55 PM
KBEUCKE
  • 78 POSTS
Can you give me a little more info on where the EGR is located?
[quote:3ad1234a14="BMRFIXIT"]EGR LOCATION
and MAF sensor[/quote:3ad1234a14]
Jan 19, 2008 at 2:05 PM
BMRFIXIT
  • 19,053 POSTS
[quote:4d325e19f0="kbeucke"]Can you give me a little more info on where the EGR is located?
[quote:4d325e19f0="BMRFIXIT"]EGR LOCATION
and MAF sensor[/quote:4d325e19f0][/quote:4d325e19f0]
engine size ??????????????????????????????
Jan 19, 2008 at 2:11 PM
KBEUCKE
  • 78 POSTS
2.0 non turbo
[quote:33071ee7cf="BMRFIXIT"][quote:33071ee7cf="kbeucke"]Can you give me a little more info on where the EGR is located?
[quote:33071ee7cf="BMRFIXIT"]EGR LOCATION
and MAF sensor[/quote:33071ee7cf][/quote:33071ee7cf]
engine size ??????????????????????????????[/quote:33071ee7cf]
Jan 19, 2008 at 2:18 PM
BMRFIXIT
  • 19,053 POSTS
left rear of engine
do you know what it look like
dont worry about it for know check the other s
wires first
Jan 19, 2008 at 2:35 PM
KBEUCKE
  • 78 POSTS
No idea what it looks like.
[quote:3f10e25d6f="BMRFIXIT"]left rear of engine
wires first[/quote:3f10e25d6f]
Jan 19, 2008 at 2:51 PM
BMRFIXIT
  • 19,053 POSTS
[quote:b563dd5761="kbeucke"]No idea what it looks like.
[quote:b563dd5761="BMRFIXIT"]left rear of engine
wires first[/quote:b563dd5761][/quote:b563dd5761]
ok I will try to get u some pic
mean while check the other
I suspect the wires
failing under load
Jan 19, 2008 at 2:55 PM
