My eclipse shut off on the highway last year for 5 mins and fired back up. Now it did the same thing a few days ago intermittently. Now it wont start at all. I dont have the cash to shotgun this thing and start throwing parts at it. I know im getting fuel you can smell it and i used a niode light to confirm pulse. I've heard of the ASD relay problem on the fire wall, bypassed the relay, same prob. I've seen a hundred people with the same problem with no real answer. I keep telling myself its the CKP sensor ($60 autozone) but its seems from reading forums that it probably wont fix my problem.
I dont have access to mitchell anymore so i was wondering if i can just test for reference voltage to and fro? There are three wires i guessing its power ground and signal return? Not sure which wire is which. Also i've heard that if the tach doesn't move when you crank then the CKP is bad. Any input would be great
Oct 1, 2010 at 7:27 PM
