The Eclipse uses 3 to 4 qts of motor oil a month and I am unable to locate the source for the leakage. There is no oil in the coolant and the valve cover gasket and rear main seal appear good. The engine is not blowing oil from the exhaust either. There is considerable oil spray along the undercarriage of the car leaving only small specks of oil on the driveway.
Where is this volume of oil leaking from?
Oct 1, 2009 at 11:27 PM
