My left turn signal is on 100% of the time when the car is turned on. Even if you place the turn signal in the position for "off" or "right turn" the left signal flashes constantly unless you remove the fuse. Emergency flashers work fine. Is this the turn signal flasher malfunctioning? Does repair require removal of the steering wheel?
Jul 20, 2010 at 10:11 AM
