1998 Mitsubishi Eclipse Cooling fans not turning on
1998 MITSUBISHI ECLIPSE
153,000 MILES • 4 CYL • FWD • AUTOMATIC
JEGARDNER
I have a Mitsubishi Eclipse GS 2.0 dual over head cam. I have had to hook jump wires up to cooling fans so I can turn them on and off so I know they work. My problem is not knowing what tells the fans to turn on, maybe a sensor and or a relay? I have looked this up in Chiltons but does not specify why or what operates the fans, Please help. Thanks Jason!
Jun 15, 2010 at 3:26 PM
Check and test the coolant temperature sensor and also if it has an engine coolant temperature gauge switch check that too -one of this two tells the computer to energize the fan relay then to the fan motor
Jun 19, 2020 at 11:59 AM
