What you have for codes all related to a tranny and or wiring
when disconnected the battery memory should erase
I would check with the tranny shop for more help
DTC 1784: LOW-REVERSE PRESSURE SWITCH
1.Remove transaxle relay from connector. Turn ignition on. Install scan tool and observe low-reverse pressure switch condition. Apply battery voltage to transaxle relay connector terminal No. 8. If low-reverse pressure switch stays off, go to next step. If low-reverse pressure switch turns on, go to step 4 .
2.Raise vehicle enough to allow drive wheels to spin freely. Test low-reverse clutch hydraulic pressure. See HYDRAULIC PRESSURE TESTS under TESTING. If low-reverse clutch pressure test is not within specification, internal transaxle failure exists. If low-reverse clutch pressure test is within specification, observe scan tool.
3.If low-reverse pressure switch turns on, trouble code is intermittent. Check wire harnesses and connectors for damage or poor connection. If low-reverse pressure switch does not turn on, replace solenoid and pressure switch assembly. Recheck trouble codes. If trouble code resets, replace TCM.
4.Check and repair wiring harness between transaxle relay connector and solenoid and pressure switch assembly connector. If wiring harness is okay, check wire between TCM connector terminal No. 10 and solenoid and pressure switch assembly.
5.If wire between TCM connector terminal No. 10 and solenoid and pressure switch assembly is okay, check TCM and solenoid and pressure switch assembly connectors. Repair connectors as necessary. If connectors are okay, recheck trouble codes. If trouble code resets, replace solenoid and pressure switch assembly. Recheck trouble codes. If trouble code resets, replace TCM.
DTC P1775 sets when 3 unsuccessful attempts to shift into 1st gear occur. Internal transaxle failure may exist including shift solenoid valve sticking or solenoid malfunction
Feb 14, 2009 at 6:01 AM
