deperate for help, replaced master clutch cylinder, than replaced slave master cylinder, even after bleeding system, the clutch pedal will eventually in a couple of minutes hit the bottom, will replacing the clutch damper help, what is its purpose, can it be bypassed, and what else could be causing this problem....perplexed and frustrated by problem.
Nov 5, 2009 at 8:13 PM
