1998 Mitsubishi Eclipse brake lights went out...where are b
1998 MITSUBISHI ECLIPSE
LSTRICKLAN
Brakes problem
1998 Mitsubishi Eclipse Manual 109000 miles
My brake lights when out and the bulbs are fine. I dont know where the brake light switches are located in my car. I was told that you could tweak the switch a little and that might be the only problem, is this true? if so, what do i do...and if not, what else could be the problem?
Feb 2, 2008 at 1:22 PM
Follow the brake pedal till it meets up with the brake support bracket-you will find the brake switch here-disconnect it and jumper the 2 terminals-the light should come On. If so adjust it .
Feb 2, 2008 at 1:52 PM
