I have a 1998 mitsubishi eclipse 2.0 non turbo with an automatic transmission.My problem is no injector pulse on # 4 cylinder (only). It pulses once when you start cranking and once again when you stop cranking. The engine starts but runs poorely. I have spark on all cylinder ,45 to 50 fuel psi and compresson of 125lbs per cylinders.
Could you tell me what could be the probably cause of no injector pulse on #4 cylinder?
Nov 18, 2008 at 10:48 PM
