1997 Mitsubishi Eclipse spark plugs
1997 MITSUBISHI ECLIPSE
VAZQUEZ13
Engine Mechanical problem
1997 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual
how do you wire spark plugs in a mitsubishi eclipse gst 1997?
May 19, 2009 at 10:53 PM
MONTY STEPHENS
  • 79 POSTS
Starting on the drivers side, that is your #1 cylinder, #4 is on the pasenger side.
The spark plug wires hook up as follows with the 1st coil closest to the dribver#1 cylinder, then moving towards the front of the car on the same coil, then 2nd coil #3, then #2.
May 20, 2009 at 6:59 AM
