1997 Mitsubishi Eclipse Runs rough at shut off / oil light
1997 MITSUBISHI ECLIPSE
132,000 MILES • 4 CYL • FWD • MANUAL
RPENRIGHT
About a month ago I had to take the car in because it wasn't starting consistantley. The cam shaft sensor was deemed bad and replaced. Since that part was replaced the car has started fine.
Prior to the cam shaft sensor being replaced when I shut the car off it would come to a very rough and almost violent stop. The car stopped and shut off fine for awhile but the problem has come up again. This time the car starts each and every time.
Also, the oil light will come on while driving. Will go off as I accelerate above 3500 rpm. Or will go off after 5 - 10 minutes of highway driving. Checked oil, level is good.
Thanks,
Ryan
Aug 19, 2009 at 1:28 PM
2CARPRO JACK
  • 11,533 POSTS
Before worrying about much, I would install a manual gauge to verify good oil pressure.The way it shuts down may be related, regardless if it has low pressure, that needs to be addressed first.Have you checked themotor mounts? it may just be that you are feeling it more sometimes
Aug 19, 2009 at 5:43 PM
RPENRIGHT
[quote:1f47ded56a="2CarPro Jack"]Before worrying about much, I would install a manual gauge to verify good oil pressure.The way it shuts down may be related, regardless if it has low pressure, that needs to be addressed first.Have you checked themotor mounts? it may just be that you are feeling it more sometimes[/quote:1f47ded56a]
How do I install a manual pressure gauge on the car? What is considered good pressure?
Aug 20, 2009 at 10:37 AM
2CARPRO JACK
  • 11,533 POSTS
best place would be to tap in where the oil pressure sender is.Pressure depends on RPM, shoul dhave at least 15psi at idle adn it should go up around 10 psi per 1000 rpm, topping out around 60 psi
Aug 20, 2009 at 11:21 AM
