About a month ago I had to take the car in because it wasn't starting consistantley. The cam shaft sensor was deemed bad and replaced. Since that part was replaced the car has started fine.
Prior to the cam shaft sensor being replaced when I shut the car off it would come to a very rough and almost violent stop. The car stopped and shut off fine for awhile but the problem has come up again. This time the car starts each and every time.
Also, the oil light will come on while driving. Will go off as I accelerate above 3500 rpm. Or will go off after 5 - 10 minutes of highway driving. Checked oil, level is good.
Thanks,
Ryan
Thanks,
Ryan
Aug 19, 2009 at 1:28 PM
