the combination switch will need to be remove for testing and in so fall replaced.
removal
Position the wheels in the straight ahead position, then turn the ignition to the LOCK position.
Disconnect the negative battery cable. Wrap the negative cable with insulated tape and wait at least 60 seconds before continuing the procedure, in order to allow the air bag system time to disarm.
Remove the steering wheel.
Unfasten the retainers, then remove lower column cover.
Remove the screw, then remove the column pad.
Unfasten the retainers, then remove the upper column cover.
Remove the retainers, then remove the clock spring and combination switch assembly
the same picture is sent to you in your email.
To install:
Install the combination switch assembly and clock spring and secure with the retainers.
Install the column covers and pad.
Install the steering wheel.
Remove the tape from the negative battery cable, then connect the cable.
Turn the ignition ON and check the SRS warning light for proper operation
Oct 23, 2009 at 2:51 PM
