I am having trouble with 2 main things on my car. The first is my backup lights. They have not worked for some time now. I have checked the bulbs and the fuses neither is the case. I'm thinking it is the backup light switch which I need to know where to locate that and how to replace it. Second my horn is not working aside from the fuse which is fine i'm not sure where to look to check on that. I believe it may not be plugged in because when I had my motor replaced it has not worked since then. I would need to know how to check that.
Dec 21, 2007 at 3:25 PM
