My question is: When I start my car and it's running idle in P park, It's like my car is barley staying on, it gets really weak and the rpm's are lower than normal I press the gas pedal to give it some gas to keep the rpm's at least above 2 so it won't turn off on me, on some occasions when my car is in D drive and I stop at a red light or stop sign my car completely shuts off on me and I have to turn the key to start the car all over again, do you guys know what the problem is?
Also theres another problem, my car is not reacting to the gas pedal, when I press the gas pedal just slightly to move about 25, 30mph it doesn't do a thing, it does a lot of putt putt putt putting, I have to press the gas pedal all the way down meaning I have to FLOOR IT just to move 25, 30mph, but eventually after about 10 times of flooring it finally it catches up with itself and acts properly, but when I turn the car off and turn it back on to use the car again that process starts all over again, that means more flooring it and putt putt putting know what the problem is?
Aug 18, 2008 at 2:29 AM
