1996 Mitsubishi Eclipse head gasket
1996 MITSUBISHI ECLIPSE
145,000 MILES • 4 CYL • FWD • MANUAL
KBYLER07
How do i replace the head gasket?
Apr 6, 2009 at 5:21 PM
MONTY STEPHENS
  • 79 POSTS
You need to spend $12 and buy a repair manual. replacing the head gasket is easy but you have to remove the over head cam which means all of the timing marks have to be lined up and you have to replace the rocker arms exactly as you found them and you have to torque everything just right.
The book will explain that and how to determine iof your head is warped or needs machining. Its a lot to go into.
Apr 8, 2009 at 8:15 AM
