MY HORN DONT WORK I JUST BROUGHT THIS CAR AND CHECKED ALL THE FUSES AND RELAYS AND CANT FIND THE PROBLEM WITH THE HORN PLEASE HELP THANKS DENNIS
Oct 11, 2008 at 2:28 PM
DOCFIXIT
CERTIFIED EXPERT
Locate horns behind front grill pull wire term use test light should be power to one then when horn is pushed other is ground. If not relay or horn contact in wheel ie. clock spring
Oct 11, 2008 at 2:35 PM
DAPAPYCHULO87
MEMBER
WELL I CHEKED THE THE WIRES ONE DOES HAS POSITIVE WHEN PRESS BUT LOOKS LIKE THE AIRBAG BEEN DEPLOYED
[quote:4a7170cc28="Docfixit"]Locate horns behind front grill pull wire term use test light should be power to one then when horn is pushed other is ground. If not relay or horn contact in wheel ie. clock spring[/quote:4a7170cc28]
