1995 Mitsubishi Eclipse high idle
1995 MITSUBISHI ECLIPSE
NHSNOWBOARDER90
  • 10 POSTS
Engine Performance problem
1995 Mitsubishi Eclipse 4 cyl All Wheel Drive Manual
my car has been having an idleing problem. When the car is cold its fine but once it gets warmed up it will idle high sometimes up to 4000 rpms the more stop and go the higher the idle is. sometimes i can tap the throttle to make it go down. also it is so bad the car will pull itself while in any gear 1-5. and the problem doesnt throw anycheck engine lights. ive checked vacumm lines and a few other things so any advice would be good keep in mind the car is a turbo
Jun 30, 2009 at 8:25 AM
JMH286
  • 6 POSTS
have you checked the idle screw on the throttle body? wait until the car is warmed up and then adjust the screw until your idle is where it should be.
Jul 4, 2009 at 4:19 PM
NHSNOWBOARDER90
  • 10 POSTS
funny part looked for the adjust screw before couldnt find found threaded hole for so went to a parts store or 2 couldnt find the specific screw so guess i should call the manufacter
Jul 7, 2009 at 11:33 PM
