The car will go into 1st gear without grinding if the RPMS drop below 1000, and into 3rd gear if you hit it just right. The car does not move whille in gear with clutch depressed. Is this 1st and 3rd gear problem a gear sinc issue or a clutch issue? IF it is a gear issue can it be repaired ( for less then the cost value of the car ). How do you confirm that the clutch is still working properly.
Note it goes into reverse 2nd and 4,5th with no issues.
Mar 25, 2009 at 3:13 PM
