1995 Mitsubishi Eclipse 1995 Mitsubishi Eclipse White Smoke
1995 MITSUBISHI ECLIPSE
119,800 MILES • 4 CYL • 2WD • MANUAL
ORLANDO210
Hi I got a 1995 Mitsubishi Eclipse that blows White Smoke from the exhaust after warming up and it smokes while just in park or ill be driving and i'll stop at a light and white smoke passes me up it is not that bad but it's noticeable. I checked the levels oil,coolant, and everything is full. I check the oil and there isn't no coolant in the oil. Is there any other problems that I can look for to see why it is smoking? Thank You
Mar 18, 2009 at 10:43 PM
Get it block and pressure tested to find out why-could be a blown headgasket cracked head or block.
Mar 18, 2009 at 11:07 PM
