1995 Mitsubishi Eclipse
1995 MITSUBISHI ECLIPSE
135,000 MILES • 4 CYL • FWD • AUTOMATIC
SHEEHAN35
light bluish smoke from tail pipe and radiator hose pressuring up a lot
Dec 6, 2009 at 7:50 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
The smoke will be smoke oil burning, how long has this been going on and when do you see it? the cooling system does run at a high pressure, this is normal, the higher the surface pressure the hight the boiling point is, so increasing the pressure allows the system to run at a temp range that will not boil, if in doubt about the pressure have the radiator cap checked, it should only hold the desired pressure then blow off, have this check.
Mark (mhpautos)
Dec 6, 2009 at 8:44 PM
