1993 Mitsubishi Eclipse brakelights
1993 MITSUBISHI ECLIPSE
10,000 MILES • 4 CYL • 2WD • MANUAL
KATHYL
i have no brake lights on my car. i have taillights and blinkers also tag light but no brake lights. when i first found out i had no brake lights i checked my fuses and found 1 of the 2 fuses were blown { right side}, i changed that fuse only. no brakelights. i then went to my manuel and found that i have a brake light switch so i purchased and replaced the brake light switch and still i have no brakelights. i did also check my bulbs and they are both good. can you please help me?
Sep 12, 2008 at 3:25 PM
KATHYL
[quote:df65f6ff7d="kathyl"]Brakes problem
1993 Mitsubishi Eclipse 4 cyl Two Wheel Drive Manual 100,00 miles
i have no brake lights on my car. i have taillights and blinkers also tag light but no brake lights. when i first found out i had no brake lights i checked my fuses and found 1 of the 2 fuses were blown { right side}, i changed that fuse only. no brakelights. i then went to my manuel and found that i have a brake light switch so i purchased and replaced the brake light switch and still i have no brakelights. i did also check my bulbs and they are both good. can you please help me?[/quote:df65f6ff7d]
Sep 12, 2008 at 3:29 PM
