1991 Mitsubishi Eclipse clutch
1991 MITSUBISHI ECLIPSE
167,000 MILES • 4 CYL • AWD • MANUAL
TYLERMNJOHNSON
  • 5 POSTS
my clutch stopped working and smoke came from the hood clutch would not disengage
Feb 21, 2010 at 11:11 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Sounds as if you have destroyed the clutch plate, but first do you still have a pedal? that is do you still have pressure on the clutch? if you have lost pedal pressure check for a fluid leak in the hydraulics, otherwise i feel it will be the box out and check for clutch damage.
Mark (mhpautos)
Feb 21, 2010 at 11:55 PM
TYLERMNJOHNSON
  • 5 POSTS
ah its my clutch fork
how do i go about fixing that
Feb 22, 2010 at 12:00 AM
MHPAUTOS
  • 31,937 POSTS
The transmission will have to be removed, do you have the equipment to do this job?
Mark
Feb 22, 2010 at 12:05 AM
TYLERMNJOHNSON
  • 5 POSTS
yes how do i do it
Feb 22, 2010 at 12:23 AM
MHPAUTOS
  • 31,937 POSTS
Info on gear box removal
https://www.2carpros.com/forum/automotive_pictures/61395_clutch_mits_1.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_mits_1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_mits_1.jpg
mark (mhpautos)
Feb 22, 2010 at 1:59 AM
