1994 Mitsubishi Diamante oil leak
1994 MITSUBISHI DIAMANTE
SMACKEY421
Other Category problem
1994 Mitsubishi Diamante 6 cyl Front Wheel Drive Automatic 150.00 miles
i have a oil leak that showed up after i changed the alternator. i have changed the pan gasket thinking that was where it was coming from but it looks like it is coming from a bolt allen style head it is on the back of the block right above the pan and below the oli filter?
Feb 11, 2008 at 11:26 AM
2CARPRO JACK
  • 11,533 POSTS
See if the bolt is loose. Did you remove anything that might have caused a leak? No leftover nuts or bolts? Try cleaning the area real good with carb spray so you can locate the exact source
Feb 12, 2008 at 7:21 AM
