Turns over real good but wont fire up. Checked for spark, but don't seem to have any! New plugs and wires!! Any help would be appreciated!!!!!!!!!
Feb 18, 2008 at 7:19 PM
BLACKOP555
CERTIFIED EXPERT
Are you using a spark plug spark tester? and using it properly?
spark should be bright and blue
post back.
Feb 18, 2008 at 10:18 PM
1PSYCHO1
MEMBER
Removed spark plug, put wire back on and held to ground on block- nothing!! Car quit running while riding down the road--engine just quit and coasted to a stop, would not restart---just turned over!!!
Feb 19, 2008 at 7:45 PM
BLACKOP555
CERTIFIED EXPERT
is there spark on all cylinders, or just one side?
distributed or Distributorless coil on plug ?
Feb 19, 2008 at 9:04 PM
1PSYCHO1
MEMBER
No spark on any cylinders,distributorless coil. There are 3 coil packs!!!
Feb 20, 2008 at 8:22 AM
BLACKOP555
CERTIFIED EXPERT
If that is the case then you should change your KPS (crank shaft position sensor) you can check it yourself if you know the proper resistance from the terminals, there is also a way to check it with a halogen light, you can right back if you want to know the procedure as it is long.
It could be your Ignition Module also but then again id have to check it to see if it is bad.
Feb 20, 2008 at 2:50 PM
BRUJITO21
MEMBER
1 POST
I have a Mitsubishi diamante 1992 no spark on 2 cilinders I put a new coil but is the same thing
