1992 Mitsubishi Diamante my car doesn't change gears, it's
1992 MITSUBISHI DIAMANTE
200,000 MILES • 6 CYL • FWD • AUTOMATIC
JERRYV@13
my car doesn't change gears it's only going on hight gear I traid changing the transmission but it's still doing the same thing what could be the problem.
Nov 21, 2008 at 10:41 AM
RMASER
  • 11 POSTS
your car has a ecu,and also has a tcu(trans controll unit)either one of these can be bad to make this car not shift
Nov 22, 2008 at 8:49 PM
RMASER
  • 11 POSTS
also in this trans,it has some shifting sylinoids that shift this trans,if the car goes in reverse and 2nd gear,this is called limp mode,this means you have troubles
Nov 22, 2008 at 9:08 PM
