1997 Mitsubishi Carisma clutch
1997 MITSUBISHI CARISMA
RICHMEISTER15
1997 Mitsubishi Carisma Front Wheel Drive Manual 91000 miles
my clutch over a hour stopped working fluid leaked all all out the seal under the bonnet filled fluid up it worked for five miles then couldnt get it in gear again but fluid level fine any suggestions please
Apr 25, 2009 at 5:41 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
It sounds as if you have air in the hydraulic system, if the fluid has been leaking out at the bottom cylinder this must be replaced & the system bleed of all air, also check that the master cylinder is not showing signs of leaking if so replace this as well.
Mark (mhpautos)
Apr 25, 2009 at 5:50 AM
