Picture if possible also i need to know what each fuse is for and where they are located pic .
Wont turn over ran out of gas a couple days before thought sit had something to with the fuel pump also maybe if a fuse is broke or missing or need a picture if you could possible appreciate it very much
May 26, 2020 at 11:10 AM
(Merged)
CERTIFIED EXPERT
The fuel pump receives voltage supply from Multi-Point Injection (MPI) control relay. Here is a guide to help you check out the relay and fuses.
