I have a '92 3000GT VR4 with about 66k miles. The car starts with no problems but when it is cold will run rich (smell of gas) and the idle will jump around from 700 rpm to about 1000 rpm. If driven when cold it will also hesitate. However, once the car is warmed up with about 10 minutes of driving it operates normally with no problems. The issue will not come back unless the car cools down for an hour or so. I just had the intake gaskets, plugs and wires, TPS and fuel filter all replaced but the problem remains. Timing belt service was done at 55k. I have not checked for vacuum leaks yet but will do that next. Any other ideas would be appreciated. Thanks.
Apr 20, 2010 at 2:32 PM
