Transmission will not go into gear
2003 MITSUBISHI GALANT
160,000 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
MAEANDMY3KIDS
The car just stopped going into gear and tried to push it in neutral, but will not move right before it stopped moving it made a clunking noise once, but sounds fine now.
Dec 22, 2017 at 11:55 AM
MHPAUTOS
  • 31,937 POSTS
No drive and a clunk sounds as if something has broken in the drive line, this will have to be checked first hand, with the engine on and the transmission in drive is there any difference to idle speed and engine speed in gear?
Dec 23, 2017 at 4:02 AM
MAEANDMY3KIDS
No, a'm thinking it is the solenoid.
Dec 23, 2017 at 10:23 AM
STEVE W.
  • 15,113 POSTS
If you put it in neutral and try to push it but it will not move I would check the shift cable and linkage on the transmission. It could be a bad cable is not shifting it properly. Would not be the first broken cable or failed linkage bushing.
Dec 24, 2017 at 4:50 AM
