Intermittent misfire while driving
2002 GMC ENVOY
125,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
At stops it wants to stall. Misses bad on and off while driving. I changed cam sensor, crank sensor, new plugs, cleaned throttle body. Still runs the same.
Dec 11, 2020 at 2:58 PM
Good evening,
Did you change the boots on the coil when you replaced the plugs? They are very common for failing.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
I would also do a compression test to be sure the internals are good in the engine.
What are the codes that are set?
May 17, 2021 at 5:35 PM
Showing no codes.
Okay, I would do the other checks I suggested.
