Sometimes the engine will stutter or miss once and then almost immediately it will do it a couple of times. to me it's like it's cutting out but my mechanic calls it stuttering.. after the first time I had the crankshaft sensor and the coil pack replaced.. the car has been good for the past two months and has done it again... the check engine light doesn't come on so the computer can't log anything in.. my mechanic says that he can't say what it could be unless it does it while he has a scan tool hooked up and then does it.. he said it could be in the harness, but without it doing it with a scan tool that reads data at the time it happens he can't say for sure.. so my two questions are, one any ideal what the possible cause(s)? And what kind of scan tool would I need that records data while the car is being driven would I need? he said he has a tool that shows data while the car is being driven but there is no way if knowing when it's going to act up...
Jul 8, 2021 at 7:31 PM
