Hello. Are there any codes? If the engine light is on and you haven't received codes, get them. Otherwise, I would be inclined to think maybe a faulty Engine Coolant Temperature sensor. The computer uses the signal from that sensor to judge how to adjust the fuel/air ratio. A faulty sensor can really screw with how the car runs. If you have access to a scanner with love data mode, I'd want to see the readings from that sensor.
Aside from that, there could be an issue with the spark plugs and wires/coils. Sometimes, as they age, coils and plugs can work poorly when hot but decently when cold, or vice versa.
Here's our guide on checking the sparks:
I'm also attaching information on how to remove and install the engine coolant temperature sensor. Use it if necessary. Let me know what you find
Apr 28, 2021 at 3:48 PM
