No problem. If the coil is good, you can just replace all the plugs. If you feel the coil could be the issue, then switch that coil with a different one and see if the misfire changes cylinders.
Here is a link that reviews and explains how to do a tune up:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Here are the directions specific to your vehicle for spark plug replacement:
2007 Nissan-Datsun Altima L4-2.5L (QR25DE)
Removal and Replacement
Vehicle Powertrain Management Ignition System Spark Plug Service and Repair Removal and Replacement
REMOVAL AND REPLACEMENT
SPARK PLUG
Removal and Installation
Exploded View EM-14
pic 1
REMOVAL
1. Remove the ignition coil.
pic 2
2. Remove the spark plug with a suitable spark plug wrench.
INSPECTION AFTER REMOVAL
pic 3
^ Do not use a wire brush for cleaning the spark plugs. Replace as necessary.
^ If plug is covered with carbon, a spark plug cleaner may be used.
Cleaner air pressure: less than 588 kPa (6 kg/cm2, 85 psi)
Cleaning time: less than 20 seconds
pic 4
^ Checking and adjusting plug gap is not required between change intervals. If the gap is out of specification, replace the spark plug.
Gap (nominal): 1.1 mm (0.043 in)
INSTALLATION
Installation is in the reverse order of removal.
pic 5
_____________________________
Let me know if you have questions and if this helps.
Jul 19, 2020 at 3:43 PM
