A rodent chewed off green wire to fuel injector connection cylinder 6. Also chewed insulation off both wires to cylinder 2. I replaced connector to injector 6 and repaired wires to cylinder 2. I started the engine and it is running very rough and knocking . Car ran perfectly before the chewed wires. Could it have messed up timing or be a computer issue? I have intake manifold off and checked for any more chewed wires. Replacing plugs while manifold is off. I had spark on cylinders 2, 4 and 6 still need to check 1,3 and 5. This vehicle listed above AWD vehicle . I really could use help with any suggestions. Thank you, Rich Norby
Nov 29, 2020 at 11:17 PM
