Where was the oil, on the part that is inside the engine or outside?
For the misfire, you need to determine what you are missing first. Could be a bad fuel injector, low fuel pump pressure, bad connection to the coil, no spark. That is where a good scan tool with bi-directional controls is a big help. It lets you shut off each item to see which effects the engine. Now without one there is another option and that is to use a noid light to test for injector pulse on the injectors, and you can use a COP coil tester to check for spark. Run a fuel pressure test to rule that out. Most of those tools are usually rental items in parts stores, except the scan tool.
Mar 28, 2017 at 7:57 PM
