Cylinder five misfiring?
2015 DODGE GRAND CARAVAN
185,000 MILES • V6 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
No check engine light but there is a misfire on cylinder 5 based on scanner. You can tell there is something going on but the degree of feeling a misfire. Is there something other than coils that is common on these? And is 5 on front or rear? It has a tick that am going to fix, the infamous lifters.
Oct 19, 2022 at 5:22 PM
SQM
  • 6,383 POSTS
The number 5 cylinder is located on the back, driver side of the engine. See attached location and firing order.
You could have a misfire due to coil, corroded or worn plug. It can also be due to a bad connection between the coil and the plug.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Let me know of any questions.
Thank you.
Oct 19, 2022 at 8:24 PM
