Hey everyone! I am completely stumped. I have misfire codes of P0300, P0302 and p0303. It starts rough on start up, then runs fine after that. Over the summer, it was overheating. After changing the two thermostats, and burping the system a couple of times, it seems to be okay. i also changed the coolant temperature control sensor. I have changed the spark plugs, coils, crank and camshaft sensors. Exhaust manifold had three huge cracks. Fixed that. No oil in coolant and no coolant in oil. Pressure tests were all steady. I am stumped. I do have a slight oil leak from the oil pan gasket, that will be fixed soon. The oil is never on the ground. Just kind of seeps.
I also want to note that I replaced the third fuel injector and cleaned the others. The third was the first misfire code I had received. The random and cylinder two followed after.
I need help. Any ideas?
Sep 9, 2017 at 7:39 PM
