I changed all six spark plugs it worked for two days now it is back doing the same. Not catching after start and shutting off. Got codes ps300 to 306 then cylinder 123 misfires. Will changing the coil packs help? Or just the fuel injectors as suggested? But during my visit a customer said check the oil it is probably throwing o2 sensor codes and others because it is low on oil. One he was right I had no oil and two after putting oil it still does it. After waiting three hours for it to cool down and start which it did not I had to drive home like the Flintstones with both feet accelerator and brake at the same dangerous time.
I want to change all coil packs. What you think?
Oct 18, 2018 at 2:40 AM
