Hello. The code P3497 is causing the other codes. First of all, check the level of the engine oil, make sure it's up to where it should be, the code has to do with the Valve-Pause System (basically cylinder deactivation to save on gas mileage). The ECM (engine computer) can activate certain oil pressure solenoids to close the intake and exhaust valves on one side of the engine. in your case Bank 2, which is why you are getting misfire codes for cylinders 3 and 6 because they are on the same side of the engine. There is a Technical Service Bulletin on this. The ECM monitors the oil pressure to determine which cylinders have been shut down. Most likely you have a failed oil pressure solenoid. You're getting the P0430 because of the misfiring cylinders. Below is the Technical Service Bulletin information.
Since you were able to shut down the car and make it home, it means you are going to have worse problems soon if the issue is not addressed. If you haven't changed your oil or it's low, it can cause this as well. On these systems you must keep up with your oil changes and keep the correct type of oil in the engine as well.
Since you are getting misfire codes, I don't think this is just a failure in the Rocker Arm oil pressure switch. I think it's going to be more of an issue with the Rocker Arm oil control valve or a failed ECM, But the failed control valve is more likely. I experienced this myself on my Honda when I owned it.
But check your oil first, and if it has not been changed in a long time, you can try that first. If the code continues to show up, you'll have to head to the dealership so they can figure out what has failed.
If you have a scan tool that can show you live data, you can try the diagnostics on page 2 below. If not, it will have to diagnosed by someone who can watch live data and see what the ECM is detecting.
May 9, 2022 at 12:56 PM
