I have had this misfire issue for about a month or so. 2 oxygen sensors, 4 coils, the mass fuel part, spark plugs have been changed out with Toyota parts. the fuel injectors have been cleaned, but still I get an intermittent check engine light, off for 3 days, then on for 2. like that.. I can feel the rough idle all the time, even when check engine light is off.. my mechanic wants to have the head gasket done. my car has not been overheating, no white smoke out of exhaust, no leaking of coolant as far as I can tell, and he has not mentioned it.. this last time the computer said 2 and 3.. a friend of mine said he should change out the 2 and 3 coils again, in case they were bad ones.. he said that if this does not work, then it is the head gasket that needs replacing.. I have also seen these sealants, such as Bar's Leaks and Blue Devil that say they can seal any leaks for some time.. I believe a compression check is in order, as well as a radiator pressure test, and a chemical test of coolant water, I think called Block Dye tester.. your thoughts on this? I have not had any gas mileage loss.. still getting average 39 miles per gallon, so probably not fuel injectors.. just don't know. your thoughts, again.. thanks, Diane
Jun 13, 2019 at 7:12 PM
