okay. the lead tech changed the spark plug and ignition coil, still misfiring we checked the fuel injector with noid lights, and it is good on that. the ignition coil is brand new. today i did a compression test i got 150 on cylinder 3 and 120 on cylinder 1. the difference between the two is cylinder 3 looks like the spark plug isn't firing cylinder 1 spark plug is blackish but cylinder 3 spark plug is new. so it could be that. I do not know. Please tell me what you think. the compression readings are as follows: cylinder 1,120. cylinder 3, 150. cylinder 5, 120.
Oct 23, 2019 at 7:23 AM
