Changed plugs,cap and rotor and new distributor. Truck starts but still has miss in cylinder three. Coil changed,no change in misfire. Lean code p0303 still persists. Pulled number 3 spark plug wire off distributor, no change in engine. I popped the fuel rail and got good fuel pressure. Engine starts fine and has no power,just a misfire that I cannot find source of. No vacuum leaks.like I said,pull number 3 wire and no change in engine. it is not getting spark only on that cylinder. Is it cam position or crank position sensor, PCM?
Dec 29, 2019 at 10:44 AM
