There's no spark on paired cyl's 4 & 7, I replaced the coil, still no spark, swapped ignition wires and they're good. Check for signal input, none to coil for 4 & 7.I assume it'd the Powertrain Control Module but I have no way to test it and I can't afford to spend $200 for a new one if it's not the problem. Is there anyway to be sure?
Thanks
Biglip
Thanks
Biglip
May 24, 2013 at 10:47 AM
