Misfire, no codes?
2000 DODGE RAM WAGON
93,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
AVALONIYEM2024
  • 20 POSTS
It all started when I changed the o2 sensor right after I changed spark plugs. I bought the van a couple months ago and have been doing a ton of preventive maintenance, so I was trying to get ahead of it.
Soon as I got on the road it started misfiring, usually when I accelerate after stopping. Just bucks like gas isn't reaching properly.
Since there were no codes, I ran my emission test on the OBD scanner and both bank 1 sensor and catalyst came back failed. Thought I had a faulty sensor or something, so I popped the old one back in. Nothing changed. Long story short, a new catalytic converter along with a new sensor fixed nothing. It occurs to me only then that the spark plugs may be to blame. Sure enough 2 of them were already burned after driving about 10 miles. Replaced all of them again and after thinking I was good for about a mile, it started again. This time it even turned off at a stop sign though started right back up. I'd never lost total power before.
I did NOT have any of these issues before the new spark plugs and sensor. Now I'm in quite a bit of money and the spark plug wires are my last guess. The boots were really hard to get off during the first change and I'm wondering if they could be damaged from getting them out and damaging new plugs? They don't have any obvious damage but I don't have experience with this. Also, I ran emissions again after driving with new catalytic and sensor (o2 passed but catalyst still failed). Plugs are all gapped properly and correct for the van. Any advice would be greatly appreciated!
Jul 3, 2024 at 6:39 PM
It is possible when the plug wires were reinstalled, they are now touching something that could have melted the insulation causing a short. Also, it is possible that the plugs were damaged.
Don't laugh, but when it is dark outside, start the engine and open the hood. See if you notice any arcing from the plug wires.
What codes are you getting?
Jul 3, 2024 at 8:12 PM
AVALONIYEM2024
  • 20 POSTS
Hey Joe, thanks for the quick reply! The thing is it's not throwing any codes. Not one. But it's jerking like crazy when I drive. The only thing that's been consistent is the catalyst "failed" when I run the emissions test. Also, when I look at the live data the short-term fuel shows gaps. Today was the first time it shut off altogether after I put the 2nd set of plugs in. Don't I have to spray some water to test for wire failure? Idk, saw it on YouTube. Thanks!
Jul 3, 2024 at 8:33 PM
AVALONIYEM2024
  • 20 POSTS
I should clarify its doing the same thing with both sets of spark plugs. Even used a different brand this time.
Jul 3, 2024 at 8:35 PM
As far as the water, you can do that. Lightly mist water on the wires. Don't get the other electronics wet.
As far as the converter, do you have a P0420 code?
Let me know. Also, I suspect there is a problem with the wires. Check that. Also, and I don't like asking, but are you certain you have the plug wires going to the correct plugs?
Jul 3, 2024 at 8:45 PM
AVALONIYEM2024
  • 20 POSTS
I'm definitely going to do the water test and let you know. I have no codes at all though on the converter. When I run codes, none are found but when I run emissions, I get that catalyst failed. But that's it. I had that same feeling about the wires today, so I double checked all the routing from the distributor to each cylinder to be sure and they were all correct.
Jul 3, 2024 at 9:51 PM
AVALONIYEM2024
  • 20 POSTS
Okay, so no sparks when I did the water test. I'm guessing that's not entirely foolproof though as the connection inside the boots could be damaged. I mean when I did the first set of plugs it was like those things hadn't been removed since the car was manufactured in 2000! I had to really pull on them to get them to budge so maybe I damaged them in the process. The whole thing is just so odd because before the spark plugs and o2 sensor went in the car wasn't misfiring at all. But as I've said I replaced the entire exhaust system aside from the manifolds. Did a soapy water test and no leaks there. I'm thinking replace the wires and rule that out next? Hell of a lot cheaper than this catalytic converter was! Thanks Joe!
Jul 3, 2024 at 10:07 PM
That is where I would start. Since it started after replacing the plugs, there is a good chance the wires got damaged internally.
Start with doing that and let me know if it resolves the issue.
Jul 4, 2024 at 7:40 PM
AVALONIYEM2024
  • 20 POSTS
Will do. Thanks so much Joe!
Jul 4, 2024 at 9:12 PM
AVALONIYEM2024
  • 20 POSTS
Have more info today (I think). Changed the wires which seemed to stop it from misfiring as frequently but still definitely doing it. Then I ran emissions and a freeze frame this time and got error p0000c8. But also my sensor and catalyst failed this time. I did disconnect the battery when changing the wires but it should still be reading from last computer read? I'm just so confused. Are all these things related to one another? Just seems like it all started with that o2 sensor and plug change. Again, its misfiring much less with the new plugs but still doing it so I'm kind of at the end of my expertise here. Any thoughts?
Jul 5, 2024 at 12:57 PM
AVALONIYEM2024
  • 20 POSTS
Sorry freeze frame code was p00008.
Jul 5, 2024 at 12:58 PM
The code isn't specific for this vehicle. However, it is a Chrysler code that indicates a misalignment between the crankshaft and camshaft. In other words, the timing is off.
In this case, it wouldn't be an electrical issue but instead, a stretched timing chain or it jumped time. On this engine, it is a straightforward design with one chain that times the camshaft and crankshaft. It would be unlikely that it has failed (not common), but anything is possible.
Please keep in mind, that code isn't listed for this year, make, and model. I just know the code. See pic below. The code list starts with P0030.
Let me know if you hear any odd noise from behind the timing chain cover at the front of the engine. Also, confirm that code for me.
Jul 6, 2024 at 9:52 PM
AVALONIYEM2024
  • 20 POSTS
I don't hear any kind of odd noises coming from the engine whatsoever. Is there any chance it could be camshaft position sensor?
Jul 7, 2024 at 2:24 PM
Anything is certainly possible. On this engine, the camshaft position sensor is located in the distributor housing. I attached a picture below showing it.
I do have another question. I just want to confirm the code you gave me. Is it a P0008?
See pic below.
Jul 7, 2024 at 9:47 PM
AVALONIYEM2024
  • 20 POSTS
Yep, that's the code. I think I initially added an extra zero. I'm going to take a look and let you know. The more I look into the timing chain itself the more it makes sense. I did remember one thing from the other day and I have no idea why I didn't correlate the two. I actually pulled over to see if the sound I was hearing was any part of my new exhaust maybe come loose. There was a small noise I hadn't heard before. I want to say kind of a rattle, but I have so much stuff in the van (it's a camper van build) including tools that I just kind of wrote it off as something inside. I didn't want to drive it too much for obvious reasons but I did just learn that its a non interference engine so that gave me a little hope as to not having screwed too much up on the test drives. The symptoms do sound a lot like the timing chain. One the heat breaks here in a couple days I'll get back out there and have a look. I really appreciate your insight into this!
Jul 8, 2024 at 12:23 PM
First, you are very welcome. I just hope I can help. LOL The 318CI engine is a very strong and long-lasting engine when maintained. At this mileage, I wouldn't have thought timing chain, but it certainly is a possibility. If oil changes were neglected, the dirt in the oil can cause the chain to wear prematurely.
Regardless, let me know if you find where that noise is. And, take your time. I was out in the sun for 12 hours today. Not fun. Between the heat and humidity, I thought I was going to pass out a few times. LOL
Jul 8, 2024 at 7:17 PM
AVALONIYEM2024
  • 20 POSTS
Hey Joe! I had a quick question about what's highlighted in the picture I attached. This is the first time I've seen this requirement in all the repair info I've researched and just wanted to run it by you and see if this was crucial? I've not seen anyone do this finding TDC but it's in my manual. Any thoughts?
Jul 10, 2024 at 1:59 PM
If I had to guess, they added that to protect themselves. LOL I don't see any specific reason that would be listed unless they worried you would start it while working.
Jul 10, 2024 at 7:21 PM
AVALONIYEM2024
  • 20 POSTS
Joe!
Hope the week is treating you well! I wanted to run these pics by you regarding TDC. My damper seems to make this easy, but my real question is can I be sure this is the compression stroke? Everything seems to line up including my distributor rotor on cylinder 1 (which is a little confusing because should this be off if I jumped timing?) Can you let me know your thoughts before I take the belt off and water pump and begin attacking this thing? As always, so much appreciated!
Jul 17, 2024 at 3:39 PM
The timing appears to be correct. Does the belt seem tight? In other words, does there seem to be enough tension and what is the condition of the belt? It could be stretched.
Jul 17, 2024 at 7:38 PM
AVALONIYEM2024
  • 20 POSTS
Well, I'm in the process of getting to the timing chain to further inspect. Removed alternator, water pump etc. I'm down to the crankshaft pulley but I am scratching my head at something...if it's so important for me to be at TDC, how would I keep it there during removal of crankshaft pulley and harmonic balancer? Wont that just turn the engine and change the timing again or is that not applicable because the drive belt is off? I'm sorry if this question seems obvious but this is my first go at something like this. Thanks!
Jul 17, 2024 at 8:28 PM
AVALONIYEM2024
  • 20 POSTS
Did you mean my serpentine belt or timing chain?
Jul 17, 2024 at 8:29 PM
I was referring to the timing chain. Sorry about that.
Jul 18, 2024 at 7:06 PM
AVALONIYEM2024
  • 20 POSTS
Hey Joe, disregard last message. Figured that part out. Gotta grab a different tool from AutoZone for the harmonic balancer to once and for all get a look at this chain. I'll let you know what I find. Have a great weekend!
Jul 20, 2024 at 9:14 PM
Thanks for the update. Take your time. I'll be here. Also, closely inspect the timing gears for wear.
Jul 20, 2024 at 10:34 PM
AVALONIYEM2024
  • 20 POSTS
Will do thanks!
Jul 20, 2024 at 10:40 PM
AVALONIYEM2024
  • 20 POSTS
Joe! Check this picture out. This is how it was aligned before I took the chain off. Confused because of the timing marks. The dots vs the slits look opposite to one another. What do you think?
Jul 23, 2024 at 4:07 PM
Actually, the two dots should be pointing at each other. In this case, the cam gear is correct if the engine wasn't on a compression stroke. See pic below.
Was there play in the chain or anything that seemed out of the ordinary?
See pic below.
Jul 23, 2024 at 7:49 PM
AVALONIYEM2024
  • 20 POSTS
The chain definitely had play. I have a new chain but can you clarify it's not correct right? See the dot on the cam gear is at 12 o'clock and so is the crank. But on this cam gear there's a dot and a slit. Only the cam gear slit is aligned with the crankshaft sprocket dot. So is my camgear completely turned around? There's a groove thats only going to allow me to install the same exact way and the dots would both be at 12 o'clock. My understanding is the cam should be at 6 o'clock. If my camshaft is completely turned around what would that indicate?
Jul 23, 2024 at 11:49 PM
Do you have an image so we can see what you are talking about?
Jul 25, 2024 at 10:02 AM
AVALONIYEM2024
  • 20 POSTS
Sure, I'll upload again. Because of the notches in the cam gear and crankshaft I would have to install the new one exactly the same way with both dots at 12 o'clock.
Jul 25, 2024 at 12:48 PM
Sorry about that, yep, the dots are the marks you want to use. I don't know why they would have lines on there.
Jul 26, 2024 at 12:42 PM
AVALONIYEM2024
  • 20 POSTS
Yeah, the new cam doesn't have a line. So, should I rotate the camshaft then? That seems to be the only way to get the dots facing each other. Thanks for your reply!
Jul 26, 2024 at 1:22 PM
Yes, turn it until the dots align as seen in the pic above. Once to that point, the number 1 piston should be at TDC and if you can see the cylinder 1 valves or cam, the valves should be the furthest away from opening.
Let us know,
Jul 27, 2024 at 8:53 PM
