My car, when accelerating from low RPM's seems to misfire at certain times. The check engine light does not flash or come on. I have changed the spark plugs and the coils and the problem is still there. It seems to happen most in low RPM and low speeds. If I give more gas, past 3,000 RPM's the problem never occurs. Only from 1500-2800 RPM's do I get this misfire like problem that happens. Not sure what could be causing it, hopefully you can help me out.
Sep 27, 2019 at 8:21 PM
