Intermittent misfire on cold start
2018 ALFA ROMEO GUILIA
9,000 MILES • 2.9L • V6 • TURBO • 4WD • AUTOMATIC
DEV IMVU
hey everyone, the story started before 3 months still dealership can't figure what cause of that misfire( only cold start). it's randomly sometimes the car runs perfect for 2 weeks no misfire cold start. they did everything; changed sparks, coil, they did test every units, injectors, evab, fuel pressure. they said everything normal, the misfire mostly came after refill the tank next morning. they checked the fuel cap also no issue with it. i'm so confused. any suggestions?
Jan 4, 2021 at 2:47 PM
I would run the codes to see what comes up but to me it sounds like the engine coolant temperature sensor may be out of range when cold. Here are guides to help us see what's going on:
and
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
and
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
Jan 6, 2021 at 9:32 AM
DEV IMVU
Hi Ken , the cold start misfire only came on cylinder “1” this is the 5th the scanner code found only happened with that cylinder, however dealership roday told me they going to open the engine head to have a check and take some diameter of some part as the factory requested that , and then they will confirm to replace the entire engine ! i'm surprised how they could think about that while the car run perfectly except that random cold misfire. i'm still thinking which internal part can cause a cold misfire.
Jan 6, 2021 at 9:56 AM
Good call there. I would thinking an injector would be more likely. Can you please let me know what happens and what they did to fix it when you get it back?
Jan 7, 2021 at 11:11 AM
