This 5.7l Vortec had been overheated, causing the need to remove and replace the heads. Machine shop said heads were cracked, so he gave a "repaired" set in exchange. Weirdest issue with those was an oil leak, external that was unexplained (lower side of head by exhaust, where there is no oil), except after being removed for the third time, it appeared to have a crack to a bolt hole the machinist missed, leaking at the end of the head, and tracking the head gasket. Machinist finally ordered two fresh blanks, and now the leaks are gone. To the current issue with the new heads 1,3,5,7 have 160-165 psi compression, while 2,4,6,8 have only 130 psi, and primarily #4 shows a misfire code, but the even bank all show random misfires. I am a shop owner, and a smog certified ASE Master Tech and this is an extra vehicle of mine. so for the last year we have been searching for answers that make sense. the only thing I could think of is perhaps there are more than one set of blank heads available with different size combustion chambers. Any thoughts or ideas are welcome.
May 23, 2019 at 1:50 PM
