It seems like you may have a vacuum leak, I have seen the intake manifold crack and create a leak. I assume you have new spark plug, correct? Also, when the spark plugs were out what did they look like, were they all the same color?
P0305 and P0301: These are OBD-II trouble codes for cylinder misfires. P0305 indicates a misfire in cylinder 5, and P0301 indicates a misfire in cylinder 1.
P0507: This code indicates that the idle speed is higher than expected.
You can use this guide when the engine is cold to see if you can find a vacuum leak:
Check out the images (below). Please upload pictures or videos in your response of the problem so we can see what's going on.
Jan 18, 2024 at 11:26 AM
